Utente del giorno: 9mm con ben 3 Thanks ricevuti nelle ultime 24 ore
Utente della settimana: 9mm con ben 8 Thanks ricevuti negli ultimi sette giorni
Utente del mese: 9mm con ben 33 Thanks ricevuti nell'ultimo mese
Pagina 1 di 4 123 ... ultimoultimo
Visualizzazione dei risultati da 1 a 10 su 38
[RECOVERY TOUCH] Team win recovery project 2.4.3.0 | OTG abilitato
    Richtc
    TeamWin is proud to present TWRP for the HTC One S!
    Post #1 - Changelog - download - installazione
    Post #2 - Utilizzo della recovey nOOb Friendly (nel pomeriggio va online datemi tempo di scriverla e fare le foto alla recovery, quelle che si trovano in rete sono della 2.1.1
    CHANGELOG :
    codice:
    2.4.3.0
    Fixed 2 bugs related to restore, one dealing with mknod failures (by bigbiff) and one dealing with restoring hardlinks (by Dees_Troy)
    NOTE: If your backups weren't restoring correctly in earlier 2.4.x versions they should restore correctly now. Hopefully you didn't delete those backups. If you're still having problems, run the restore, go to advanced and copy log, then give us the log. Complaints without logs will be rightfully ignored.
    Added a scroll bar to file selectors and listboxes courtesy of Tassadar
    Added libblkid for more accurate detection of file systems and can now detect exFAT properly thanks to bigbiff
    Added a screen dim effect 2 seconds before screen off on some devices
    Finally fixed file selector crash (one of the joys of working with multi-threaded software)
    Fixed loading of screen timeout setting during startup
    Improvements and bugfixes to screen timeout code
    Fixed persistence of the 24 hour / military time setting
    2.4.2.0
    -Add screen timeout - screen will turn off automatically after 60 seconds, saves battery and prevents screen burn-in especially on AMOLED devices
    -Add a brightness setting (requires device specific setup and only some devices have been added)
    -Add a root checker and offer to install SuperSU if the device isn't already rooted
    -Add a write buffer to libtar backups, significant improvements to speeds when backing up to exFAT target, minor improvements for other file systems
    -Check and offer to fix root permissions if broken
    -Add an option for a 24 hour clock display instead of AM/PM (aka military time)
    -Move stock recovery reflash check to occur during the reboot cycle
    -Add support for some MTK6xxx devices
    -Change libtar to vfork to help prevent memory problems
    -Add a "clicked" effect to most buttons, file selector, and listbox
    -Improve timezone listbox to be more like file selector (per pixel kinetic scrolling, etc)
    -Remove some no longer used settings (Forced MD5 sum on zips, size checking on image backups)
    -Other minor bugfixes and improvements
    2.4.1.1
    -Added USB OTG support
    -Updated kernel from HTC (may result in short lag when rebooting out of recovery and a color shift when using aroma)
    2.4.0.0:
    Using libtar instead of busybox's tar for better control over tar file creation and breaking the 2GB barrier that busybox imposes (thanks to bigbiff)
    Support for exFAT formatted sdcards (also thanks to bigbiff)
    Support for decrypting Samsung TouchWiz encrypted devices including internal and external storage (special thanks to a3955269 for figuring it out)
    Improvements to OpenRecoveryScript including displaying a proper GUI while the script is running
    Added wipe cache and dalvik after ADB Sideload
    Replaced many system calls with their native C counterparts
    Fixed bugs in file manager where it would display an empty list after moving or deleting a folder
    Fixed AOSP recovery commands to run after decryption on encrypted devices
    Improvements for building TWRP in CM10.1
    2.3.1.0:
    Unmount system after boot to prevent some status 7 symlink failed errors on zip install
    USB Mass Storage code improvements
    Better handling of mounting storage during boot for some devices
    Fixed a problem with sizes of images (boot & recovery) after resetting defaults
    Fixed size errors during backup for some devices on recovery, etc.
    Fixed a problem with restoring backups when multiple archives were present
    Special credits:
    toastcfh for the device work and rhcp for the initial build and testing
    Full TeamWin credits are on the TWRP page on the TeamWin website: TeamWin Projects - TWRP 2.2 | TeamWin
    Team Win Recovery Project, o twrp2 in breve, è una custom recovery progetata per la facilità d'uso e di customizzazione. è interamente touch quindi non si utilizzano più il tasto power e il bilanciere del volume. la GUI è totalmente in XML e perfettamente temabile, quindi in futuro avremo la possibilità di avere anche la recovery temata
    DOWNLOAD:
    in alto a destra scegliete "get twrp for your device"
    digitate "one s"
    scegliete la recovery a seconda se avete la variante S3 o S4 -> NON SBAGLIATEVI <-
    Installazione con FLASH IMAGE GUI
    scaricate la recovery che è .img
    aprite flash image GUI e selezionare recovery
    Con browse andate a cercare la vostra recovery.img
    flash
    normal reboot
    Metodo con Fastboot:
    collegate il telefono al pc in modalità solo carica
    aprite il terminale e spostatevi con cd nella cartella dove avete fastboot e adb
    digitate
    adb reboot bootloader
    fastboot flash recovery nomerecovery.img
    fastboot reboot
    Immagini allegate
    Ultima modifica di Richtc; 04-03-13 alle 15:23
  2. Il seguente Utente ha ringraziato Richtc per il post:
    Rob38 (06-01-13)
    Richtc
    Guida nOOb Friendly della twrp recovery
    Interfaccia
    La recovery twrp 2.4.1.1 supporta l’usb otg e questa è la grande novità. Potremo girare con chiavetta usb, cavetto otg e creare nand backup direttamente sulla chiavetta oppure tenere tutte le rom su chiavetta e flasharle sfruttando l’otg…così recupereremo un sacco di spazio sulla sdcard . Il menù principale è così suddiviso
    Install
    Da qui andremo a scegliere il nostro file .zip da flashare, abbiamo la possibilità di scegliere tra memoria interna (quella del one s) e esterna (una penna usb ad esempio ) andremo a scegliere il nostro file.zip premendoci su e scorrendo il dito nella parte inferiore per far partire il flash. È possibile anche aggiungere più zip in coda (ad esempio nelle rom Aosp bisogna flashare la rom + Gapps, in questo modo farà tutto insieme)
    Wipe
    Qui abbiamo i vari wipe. Con questa versione è possibile anche formattare la memoria esterna (penna usb) e la memoria interna (sdcard interna. Consigliabile farlo sempre da pc e non da telefono)
    Queste le sequenze di wipe da fare nei vari flash
    Flash rom
    factory reset
    wipe system
    wipe cache
    wipe dalvik cache
    Flash kernel da fastboot
    Flash della boot.img
    Fastboot erase cache
    Flash del kernel da flash image gui
    Automaticamente formatta cache e dalvik cache
    Backup
    Qui potrete fare i vostri nand backup, potrete dargli il nome con “set backup name” e selezionare le partizioni di cui crearne il backup, impostate di default “system, data, boot”. Con questa nuova versione potete scegliere su quale memoria fare il backup, esterna (penna usb) oppure interna (sd interna)
    Restore
    Qui ripristiniamo i backup, l’intero backup oppure le singole partizioni, utilissimo per ripristinare la partizione data.
    Ricordiate sempre che per ripristinare un backup avete bisogno di flashare la boot.img da fastboot quindi non potrà esservi molto utile se sarete in giro senza un portatile sottomano
    Mount
    Qui potremo montare e smontare la nostra sd interna collegandolo al pc. È possibile anche montare la partizione /system e poi sfogliarla con il file manager presente nel menù Advanced
    Advanced
    Qui potrete sfogliare con il file manager il contenuto della root del telefono. Molto utile per sostituire un file di sistema che non vi permette di far funzionare correttamente ma solo se avete la rom estratta o l’apk da sostituire nella sd
    Reboot
    Qui possiamo scegliere dove riavviare il telefono, riavviare la recovery, il bootloader, system (si riavvia il telefono normalmente) o semplicemente spegnerlo
    That’s all Folks!
    Temi per la recovery!
    Download
    MD5 Sum: c4ee40259bdaacd08453016592ff8421
    Come installarlo:
    Aprire con un gestore file la cartella TWRP presente nella sdcard
    Aprirla e creare al suo interno una cartella chiamata "temi"
    Copiare il ui.zip nella cartella e riavviare in TWRP
    Enjoy new theme
    Inviato dal mio HTC One S con Tapatalk 2
    Ultima modifica di Richtc; 09-02-13 alle 16:11
  5. #3
    Androidiano VIP L'avatar di sirio87s
    Jan 2011
    Lucera (FG)
    nokia. poi è arrivato android!
    Ringraziato 132 volte in 115 Posts
    cambiare il titolo del thread perché è uscita la v2.2.0!
    USA I TASTI CERCA E THANKS!
  6. #4
    Richtc
    Se che ppalle devo chiederlo al mod :banghead:
  7. #5
    Htc One S
    Ciao a tutti, sono 2 giorni che smanetto ma a me la TWRP non installa il boot.img e devo farlo manualmente tramite fastoobt, qualche idea? c'è qualcosa che devo fare in più oltre che a flashare semplicemente la recovery?
    Jan 2011
    Lucera (FG)
    Il tuo problema dovevi scriverlo nel thread della rom che provi a flahsare (e che non hai neanche scritto!).
    Inviato dal mio HTC Desire usando Androidiani App
  9. #7
    Htc One S
    Guarda in realtà ho provato a flashare la CM9, la trickdroid e la paranoid android e tutte e 3 mi davano lo stesso problema! quindi credo sia un problema della recovery!
  10. Il seguente Utente ha ringraziato thencl per il post:
    deskjet (20-07-13)
  11. #8
    Richtc
    Che versione della TRICKDROID?
  12. #9
    Htc One S
    Quote Originariamente inviato da Richtc Visualizza il messaggio
    5.1, ma ripeto non credo sia un problema di rom perché il problema me lo da su tutte le rom :S cioè temo di dover cambiare qualche impostazione della recovery che io non so :S
  13. #10
    Richtc
    È l'ultima versione? Io non ho impostato niente in recovery..
